Uneven tire wear issue
Discussion in 'Ask An Owner Operator' started by Bains, May 31, 2020.
  1. Bains
    Bains Bobtail Member
    33
    14
    Sep 20, 2018
    Hello fellows ,
    It’s only 180,000 Kms on new drive Yokohama tires . I noticed one tire start eating threads . It’s driver side - rear - inner eating essential inner threads (2” wide spots all around with 1-1/2 feet gap .
    Rotation and alignment is done 20k kms ago . That time they were totally fine . I’ll really appreciate your help .
    Please check the picture
    Doealex Thanks this.
  3. Spyro2112
    Spyro2112 Medium Load Member
    627
    437
    Mar 17, 2018
    Air pressure
    Bains Thanks this.
  4. sirhwy
    sirhwy Medium Load Member
    347
    709
    Sep 1, 2011
    Central Iowa
    I was told that is due to axle flex. I have no technical knowledge to offer, but that is what I was told. Someone may have better info for you.
    Doealex and Bains Thank this.
  5. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    It almost looks like the shock is malfunctioning sometimes. Ever since I replaced my Volvo shocks with cheaper Gabriel shocks I’ve had the same issue with my drive tires. I guess you get what you pay for. :(
    Bains Thanks this.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    With any inside edge of tire wear the wheel bearing end play need to be reset with a end play tool that clamps on to axle and rests on hub, every time you tighten the outer nut you ck. the end play till you get it in spec, it takes a few times to get it in spec. But all the tires need to be ck. before you leave out when tires are cold and aired up to same press. every week?
    Bains Thanks this.
  7. Bains
    33
    14
    Sep 20, 2018
    Shocks could be the reason . I’ll get it changed and let you know . Ty
  8. Doealex
    597
    1,132
    Feb 21, 2018
    I am going to change my shocks when I replace tires. Too late to change shocks now.
  9. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Could it be the leveling valve?
  10. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    First check air pressure. Second rotate tires and rims in a X pattern. While that tire and it's neighbor are off swap rims.
    This way you can determine if it is a problem with that wheel position (bearings/ axle flex) if the wear starts in that position again. Swapping rims between the 2 tires will determine if you have a bad rim, tire or the tire was not mounted properly. I dealt with this on a set of Goodyears. 3 inside tires had wonky wear outside wore relatively even. My issue was rims.
    feldsforever and Doealex Thank this.
  11. Doealex
    597
    1,132
    Feb 21, 2018
    Deleted
