unexplainable electrical problem {lights}
Discussion in 'Freightliner Forum' started by dixieworkx, Aug 10, 2013.
  1. dixieworkx
    dixieworkx Light Load Member
    52
    25
    Nov 15, 2012
    okay have removed, cleaned, checked, and replaced the 7 pin connectors {both as i have 2}, everything was fine, no corrosion, and a good layer of white contact grease...cable fine...disconnected all the lighting {brake lights/running lights/reverse lights/blinkers} to the rear of the tractor at the 5th wheel,, and still have the same problem...in process of tracing out every wire which should be quite interesting considering a 13 yr old truck haha...
  3. dixieworkx
    52
    25
    Nov 15, 2012
    ok update #@%*&%$ seriously though, have checked lights no water ot corrosion,,,checked connectors,,,found 1 broken ground fixed it now the brakelights dont work at all, and none of the other lights come on with the brake pedal or trolley valve anymore...every clearance light/running light still coming on with ignition switch....with ignition switch off all light switches turn on/off everything just like they should....turn on ignition switch they all automatically come on and cant be turned off except by turning off ignition,,,,funny thing the headlights and the taillights are on the same curcuit and same switch yet the headlights work like they are supposed to but the taillights work like they want to...the best part, the one that makes it all worthwhile, is that nearly every single wire on the truck is either yellow or white....follow that awhile !!!!.
  4. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    if you are able to read the little white stickers on your middle dash relay panel,when you pull the correct relay you will probably find it is green.you should also pull every single one,there will be more than one water logged.common on FLD.water leaks from bottom of windshield,destroys relays.good luck.
    tdmccree64 and dixieworkx Thank this.
  5. dixieworkx
    52
    25
    Nov 15, 2012
    qualitytruck...while your offer of help didnt help with my ''important'' problem that i am dealing with, it did make me get down on my back and really check out the fuse/relay panel...having looked into it many times, including several times in the past couple days, until i laid on my back today i never even noticed the *other* row of relays that is tucked neatly into the top of the panel...and yes, a couple were quite corroded/green, and yes you helped cure a few minor problems i have had since i bought the truck...you are the winner of the electrical guru award for the week !!!!! THANK YOU !!!!!...too bad all the white labels are unreadable.....
    so, replaced a leaking brake light switch {man that was fun}, checked out every single fuse/breaker/relay, traced wires all over the place for 9 hours today alone, , and as of this minute i am no closer to locating my problem then i was when i first started...and i have quite a bit of electrical experience , not a novice, in fact i once rewired every single wire in a 76 toyota corolla sr5 after the voltage regulator decided 12 volts was not enough and it melted the insulation off nearly every wire on the car...but this has me staring at the floormats...
    tdmccree64 Thanks this.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    We had a 2001 FLD that all the markers would come on with the ignition switch. The truck was wired for Canada that tied fog lights to the tail lights. The problem was in the wiring to the fog light switch.
    If you're truck is wired like fig 2 in this link, pull the fog light relay and see if the lights stop coming on with the key.
    http://ww2.justanswer.com/uploads/gowest/2011-03-20_211710_drl.pdf
  7. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    should have also told you to check with your test light, at bottom left hand corner of panel,the wires that lead to your 7 way plug.they are all color coded same as at rear of 7way.disconnect all of them and try it,that will rule out anything trailer harness related.
  8. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    by the way if you search this forum,someone posted an easy to read diagram of relays since those stupid stickers are always faded.good luck.
  9. Trukdrvr
    Trukdrvr Bobtail Member
    8
    Feb 21, 2019
    Hello, I know this is 10 years ago but were you able to find what the problem was? I'm having similar issue. Clearance lights coming in with ignition switch on
