Uniden 68 elite
Discussion in 'CB Radio Forum' started by midnight rumbler, Apr 6, 2007.
  1. midnight rumbler
    midnight rumbler Bobtail Member
    18
    Hey guys,
    After a near miss yesterday coming up over a hill at 65 miles an hour only to find a break-check, i am investing in a Uniden 68 elite.
    What is the best coax to wire this baby up and what antenna's should I buy that would be most compatible for the Uniden. My truck is a dual system antenna set-up.
    thanks in advance
  3. tfisher63
    tfisher63 Light Load Member
    83
    Oct 22, 2006
    Casper WY
    By dual system, do you mean two antennas or that the antennas are also used for am/fm radio too? If the antennas are dual purpose, consider using a single setup for each. Wilson Silver Load or Firestick antennas are good choices, fairly inexpensive and work well. both are available with swr adjustment feature that doesnt require trimming. Look for a co-phase harness made from Belden cable if you run two antennas. Or you can just run one antenna if you want, with a single co-ax. The dual setup offers a little better performance, but not a huge difference. A single setup will save you a few bucks and is simpler. Buy a good mount, stainless if you can find one.
  4. Cybergal
    Cybergal Road Train Member
    6,272
    2,399
    Oct 20, 2008
    I would go with a 5 foot fiberglass dual phase antenna, as this may give you better reception.
