Unladen weight
Discussion in 'Flatbed Trucking Forum' started by Diligent_Transport, Sep 14, 2022.
  1. Diligent_Transport
    Diligent_Transport Bobtail Member
    49
    51
    Mar 25, 2022
    New truck and new flatbed, I got all my tools and supplies loaded on and hit the scale to see where I was when empty.
    Steers 11,100
    Drive 10,520
    Trailer 7,720
    Are steers normally that high when empty? I know the load doesn't add a whole lot to the steers, but still, I feel like I'll be pushed over 12k easily.
    Fifth wheel all the way back.
    Will this be a problem?
    cke Thanks this.
  3. Diligent_Transport
    49
    51
    Mar 25, 2022
    Looking up my axle on the front, I guess the axle is rated up to 13.2k, so I guess when I get to my truck here in a couple hours I'll have to see what the tires are rates for
    cke Thanks this.
  4. cool7035
    cool7035 Light Load Member
    111
    184
    Aug 6, 2013
    Rusk, Texas
    My KW 680 is the same. I hover around 10700 and 11200 on the steer all the time.
    cke Thanks this.
  5. Long FLD
    Long FLD Road Train Member
    12,869
    53,853
    Mar 4, 2015
    You won’t add much at all, if any, to the steer with your 5th wheel back depending on where all the way back is on your truck. You don’t really start throwing a lot of weight into the steer until your 5th wheel gets up forward of the center of your drives.
    cke and Lite bug Thank this.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    That's about where my truck is, wish my father wheel slider wasn't seized as #### so I could slide it back a notch or 3.
    cke Thanks this.
  7. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,358
    Nov 1, 2017
    The Sticks, Idaho
    Pressure washer, penetrating oil, a big bar, and maybe a big hammer.
    Bean Jr., cke and Feedman Thank this.
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Tried that, let er soak for a few days, no luck. It was froze when I bought the thing 6 years ago.
    cke and Cattleman84 Thank this.
  9. AKDoug
    AKDoug Medium Load Member
    323
    802
    Mar 21, 2018
    You should be fine. My new T880 runs almost identical to you. I run my 5th plate barely to the rear of center on the drives. At full drive axle weight I am allowed at 38K I don't exceed 12.5K on my steers.
    Bean Jr. and cke Thank this.
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Try it dry. If you can’t get red dust flying everywhere with an air nozzle and an air chisel, save your effort and find another slider rack.
    Bean Jr., cke and beastr123 Thank this.
  11. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    It'll be fine on the old turd for awhile. It needs a lot of work and money that I'd rather just put in my 359.
    cke and kranky1 Thank this.
  12. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,478
    Mar 18, 2021
    St Malo mb
    T
    try cranking trailer high then dump truck air so it has weight pulling on it .. sometimes that with penetrating oil will break it free overnight.
    beastr123 and cke Thank this.
