Unloading dextrose from pnumatic tanker. Aerators?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Mshepyy, Oct 4, 2022.
  1. Mshepyy
    Mshepyy Bobtail Member
    Oct 4, 2022
    They sent me to deliver dextrose from a pnumatic trailer. Do I need to avoid using aerators because of the heat as you would with sugar?
    77fib77 Thanks this.
  3. Suspect Zero
    Suspect Zero Road Train Member
    2,538
    9,787
    Oct 10, 2016
    Brookfield, IL
    I use aerators with dextrose almost all the time, but then again I use them on sugar too. Just keep an eye on your blower temp. I usually set the top and bottom valves then use the product valve to adjust the pressure and keep the temp down to something reasonable.
    REO6205 Thanks this.
