2020 Volvo day cab. We've gotten eight new semis at my company, and everybody has noticed a tracking on the road issue really bad. It's almost like they're drifting left and right when you're holding the steering wheel straight. Anybody else with this issue?
Unstable driving down the road
Discussion in 'Volvo Forum' started by Jon Wheeler, Oct 14, 2020.
its called wander. the caster is set at zero from factory. you need to have the caster adjusted. it needs some pull towards each other to keep it tight.KB3MMX, Echo5kilo, DUNE-T and 1 other person Thank this.
just look up wander and info on caster adjustments.
Are your trucks equipped with Hendrickson Steertek air spring steer axle?
truckdriver31 Thanks this. -
How many miles on them?
Which tires?86scotty, truckdriver31 and Goodysnap Thank this. -
its what i told him.
Curious...no further info on this? Alignment is a good one to check for sure.....i just see a few other posts on this problem and it seems to be common to this axle after a bit of mileage...was wondering if anyone has sorted it out.
Caster doesn’t do that. Caster is the forward or rearward tilt of the steering.truckdriver31 Thanks this.
I’ve had this happen with really deep tread depths on drive tires especially around 24/32.KB3MMX, RoadRanger^^, Goodysnap and 1 other person Thank this.
i would put $100 on the front is set to zero from the factoryKB3MMX Thanks this.
