Unusual trailer brake issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pmracing, Jan 11, 2017.
  1. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Hooked the trailer, hooked hoses and elec. Aired it up and put my weight on the trolley handle to walk around and listen for air leaks. None heard.
    I released both brakes and rolled a bit to do a tug test with the trailer brake lever. All is good.
    I set the trailer brakes to slide the tandems forward, all pins are in, but ZERO BRAKES! The trailer just rolls!
    So why would brakes work with service pedal, trailer brake lever but no brakes when the red knob is pulled?
    Mikeeee
  3. Blackshack46
    Blackshack46 Road Train Member
    Because service brakes are air applied. Parking brakes are applied by the spring. Spring has no where near the brake application of 80psi of air.
    Release trailer brakes and use johnny arm to hold trailer while sliding.
  4. Powder Joints
    7,988
    8,407
    Sep 25, 2007
    Rosamond, SoCal
    two different sides of the brake chamber, the red knob dumps the air activating the spring brakes.
  5. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
    Springs broken in maxi chambers. The springs rust through and break, and then that brake won't hold with only the spring, service brakes are unaffected.
    Lease company actually put brand new cans, 4 of them, on the Cascadia I drive and they were all working like they were supposed to. Couldn't tell the difference but I guess that's the point.
    Ooops, Bean Jr. and Dave_in_AZ Thank this.
  6. Pmracing
    6,354
    3,178
    Jan 28, 2011
    If I release the brakes the pins will pop out. How do I slide the tandems then?
    Mikeeee
  7. Pmracing
    6,354
    3,178
    Jan 28, 2011
    All four trailer brake springs might be broke?
    Mikeeee
  8. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    If you have air operated pins, you can't do that, it's block the axle somehow and slide it that way.
    Love it when the cans have been replaced, and it works like it is supposed to.
    Dave_in_AZ Thanks this.
  9. Blackshack46
    We have spring released pins. A couple are air. My suggestion would be to somehow hold the button on the trailer you use to pull the pins in.
    Or find a curb of some sort to block the wheels.
  10. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    Maybe all be broken if they are all the same age, and they weaken before they break. You can tell s9mewhat by making the drums thud (applied) or ring(not well applied) by striking them with a hammer. Find a curb or something to block the wheels to slide it now.
  11. Pmracing
    6,354
    3,178
    Jan 28, 2011
    I know the curb trick. I am salaried. I would rather fix the problem as opposed to passing it down the line to an OTR driver that needs miles. Plus it was going to PA and I think the mountains were going to be a bit snowy by the time it got there (on the train).
    Mikeeee
    25(2)+2 Thanks this.
