Upgrading front axle on 2008 Cascadia from 12,000 to 13,200 lbs
Discussion in 'Freightliner Forum' started by rbrauns, Feb 29, 2020.
  1. rbrauns
    rbrauns Light Load Member
    164
    56
    Dec 7, 2014
    My 2008 Cascadia has worn out front springs. They are rated at 6,000 lbs each.
    I run flatbed, triaxle (I'm from Canada) and run always heavy. With my fifth wheel all the way back and a heavy load (my last one was 64,500 lbs of lumber) and the 100 gallon tanks half full, I was only 200 lbs under the max weight on my front axle. I'd be 200 lbs over if my fuel tanks were full.
    So, with my front springs worn out, I'm wondering how hard is it to put 6,750 lb springs in and have the front axle rerated to 13,200 lbs. Or is the i beam different? I asked my dealer but he wants the VIN and tells me no way to upgrade.
    Does anyone know?
    If I had heavier front axles, I could install 150 gallon fuel tanks some day.
  3. Deere hunter
    2,499
    14,188
    Aug 5, 2017
    Shallowater Texas
    We have just added springs to desired weight rating! Never changed axle , one truck been that way for 7 years no problems!
  4. Rcranch81
    Rcranch81 Medium Load Member
    351
    2,199
    Mar 7, 2020
    Well if your from Canada isn’t the law you can only be 12500 on your steers anyway?
    free2fly973 Thanks this.
  5. Rcranch81
    351
    2,199
    Mar 7, 2020
    My bad 12200
  6. Capacity
    Capacity Road Train Member
    1,499
    3,119
    Jul 28, 2019
    Neenah Wi
    You can always run a heavier bus tire on the steers , we did Michelin makes them.
  7. bonder45
    bonder45 Road Train Member
    1,803
    5,456
    Oct 2, 2011
    Williston, ND
    Technically we can run up to 20,000 lbs on the front axel with the proper tires.
  8. rbrauns
    164
    56
    Dec 7, 2014
    Just following up. I asked a few spring and axle places and they all said that Freightliner has to do the upgrade and note it on the sticker. The dealer told me that I would have to upgrade the whole front axle, not just the springs.
