Upgrading tomorrow!
Discussion in 'Questions From New Drivers' started by Penumbra, Oct 20, 2019.
  1. Penumbra
    Penumbra Medium Load Member
    305
    528
    Jul 29, 2019
    Well everyone, after being stuck alone in a hotel in Ohio for 3 nights, I will be finishing my upgrading tomorrow.
    I did most of the written tests when I got here. I need to do the road test (it’s an automatic so I’m not too worried about that), backing test, and pretrip test.
    the only two things that worry me are:
    pulling the trailer out from between two other trailers. Sometimes, I get behind the wheel and it seems like no problem, other times it feels like the wall/row of trucks in front of me is too close and I have a hard time pulling out and turning without getting too close to the trailers beside me, or I have difficulty getting pulled out then turning hard enough to avoid hitting the obstacles in front of me.
    secondly, 45 degree backs. I know HOW to do them, but setting myself up for them, then reading what my trailer is doing is really difficult for me. It just feels like I’m shooting blindly at the hole and hope I hit it. I’m having real anxiety about having to do that in truck stops at the end of my shift. I’m worried I won’t be able to get in, and that I’ll not be able to find a place to park before my HOS is up!
    advice would do wonders to calm me down going into tomorrow!
  3. austinmike
    134,707
    well, sorry you are stuck in ohio. me and that state dont get along lol - dont over think things - easy to say but not so easy to do - youll be fine - good luck
    TravR1 and D.Tibbitt Thank this.
  4. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Backing up an automatic truck is different than a stick shift. You can't ride the clutch and you have to be careful on lining up.
  5. LtlAnonymous
    6,084
    21,048
    Dec 23, 2016
    As far as pulling out from between two trailers, just square off your turn. Don't touch the wheel until your trailer wheels are at the front of the trailer on your side.
    45 degree backing...takes much practice. Just hug the driver's side of the spot with your trailer so you can see what you're doing and have extra space on the passenger side.
    TravR1, Farmerbob1 and starmac Thank this.
  6. Penumbra
    305
    528
    Jul 29, 2019
    Square off meaning pull straight then turn hard?
    LtlAnonymous Thanks this.
  7. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I have been in places where I had to pull straight too far to make the turn, make what you can and back up just enough to finish the turn.
  8. LtlAnonymous
    6,084
    21,048
    Dec 23, 2016
    Yes, exactly.
  9. LtlAnonymous
    6,084
    21,048
    Dec 23, 2016
    Yeah that, or if you're turning right, you can button hook to the left. That helps as well.
  10. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
    Good luck
  11. Penumbra
    305
    528
    Jul 29, 2019
    I passed. 2 pull ups because I didn’t chase quick enough, but I was in control and knew what I was doing.
    TravR1, D.Tibbitt, Concorde and 2 others Thank this.
