URGENT question about the DOT HOS
Discussion in 'Experienced Truckers' Advice' started by CoveringBases, Feb 23, 2017.
  1. CoveringBases
    CoveringBases Light Load Member
    103
    65
    Jul 8, 2016
    I'm stuck in totally non-moving traffic on Donner, heading west, 74 miles from Sacramento. There was a sign a couple of miles ago saying there was an accident 5 miles ahead, and to "drive carefully," but now we've been just sitting here for an hour. I have 13 minutes left on my clock.
    I do not think I could have adequately foreseen this. The pass isn't even bad enough to warrant chains. However, all rest stops since climbing the mountain have been filled with piles from the snow plows, and closed. What could I do?
    And what can I do now?
    Update: we finally got moving and inched along, and I pulled off at the first safe and legal place I could find.
    I don't have a CB. :confused:
    I LOVE Trucker Path, but I've been using it solely for truck stops and weigh stations. I'll have to play around with it to see what else it can do.
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    You find the first legal parking and park it. Note what happened and go to sleep.
    jammer910Z, rank, Oxbow and 4 others Thank this.
  4. ChaoSS
    3,338
    6,758
    Sep 20, 2014
    Exit 145 is just past that accident it looks like. Should be parking available.
    rank, milehunter43 and CoveringBases Thank this.
  5. CoveringBases
    103
    65
    Jul 8, 2016
    If we ever start moving again!
    Where did you get that information? I only have one app for California, and it's not showing this at all.
  6. ChaoSS
    3,338
    6,758
    Sep 20, 2014
    I'm just looking at truckers path. I think I've stayed there before but I'm not sure, I don't do Donner too often.
    Truckers path has a traffic layer, I think it just uses Google maps for that.
    Chewy352 Thanks this.
  7. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Log it as you drive it, I believe there's a provision for weather and emergencies, you just can't use it all the time. I'm sure some will elaborate or correct me on this.
    Loose Leaf Thanks this.
  8. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    Any info on the CB? Can you or did you go off duty or edit yourself off.
    All you can do is park at the place that's legal to do so.
    send a message to your safety dept or to whom ever
    G13Tomcat Thanks this.
  9. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,143
    Jun 7, 2011
    ^^^^^ Safe Haven~
    EZ Money and slim shady Thank this.
  10. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Turn the volume down and keep going til you get to a legal place to park.
  11. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Safe Haven is only for HazMat...
    “Safe Haven” is covered in FMCSA regulations, here:
    § 397.5: Attendance and surveillance of motor vehicles.
    (a) Except as provided in paragraph (b) of this section, a motor vehicle which contains a Division 1.1, 1.2, or 1.3 (explosive) material must be attended at all times by its driver or a qualified representative of the motor carrier that operates it.
    (b) The rules in paragraph (a) of this section do not apply to a motor vehicle which contains Division 1.1, 1.2, or 1.3 material if all the following conditions exist—
    (1) The vehicle is located on the property of a motor carrier, on the property of a shipper or consignee of the explosives, in a safe haven, or, in the case of a vehicle containing 50 pounds or less of a Division 1.1, 1.2, or 1.3 material, on a construction or survey site;
    and is defined as:
    an area specifically approved in writing by local, State, or Federal governmental authorities for the parking of unattended vehicles containing Division 1.1, 1.2, or 1.3 materials.
    Adverse Conditions is what applies.
    § 395.1: Scope of rules in this part.
    (a) General. (1) The rules in this part apply to all motor carriers and drivers, except as provided in paragraphs (b) through (r) of this section.
    (2) The exceptions from Federal requirements contained in paragraphs (l) and (m) of this section do not preempt State laws and regulations governing the safe operation of commercial motor vehicles.
    (b) Driving conditions—(1) Adverse driving conditions. Except as provided in paragraph (h)(2) of this section, a driver who encounters adverse driving conditions, as defined in § 395.2, and cannot, because of those conditions, safely complete the run within the maximum driving time permitted by §§ 395.3(a) or 395.5(a) may drive and be permitted or required to drive a commercial motor vehicle for not more than 2 additional hours beyond the maximum time allowed under §§ 395.3(a) or 395.5(a) to complete that run or to reach a place offering safety for the occupants of the commercial motor vehicle and security for the commercial motor vehicle and its cargo.
    (2) Emergency conditions. In case of any emergency, a driver may complete his/her run without being in violation of the provisions of the regulations in this part, if such run reasonably could have been completed absent the emergency.
