Using jakes on long downhills
Discussion in 'Experienced Truckers' Advice' started by InTooDeep, May 8, 2018.
  1. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Is it hard on the engine using jakes on a long downhill runs. Just wondering if using them for extended periods of time. Does running them cause any damage like from lack of lubrication or anything?
    Oxbow Thanks this.
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    No. That's exactly how they are intended to be used.
  4. MACK E-6
    50,061
    238,661
    I’ve certainly never heard of it happening.
    I did have a co-worker tell me once that with our new trucks using the engine brake will cause the consumption of more DEF, however that may be possible. :?
    Aces-N-Eights Thanks this.
  5. TripleSix
    133,411
    Years ago (2008), had a friend get a brand new 4 axle heavyhaul rig. He pulled a 230k load through the mountains and jaked it all the way down. He got to the bottom and had to do a regen. The shoulder suddenly gave way. He looked in the mirror and saw the trailer and the stinger lean over. The the jeep. All he had time to do was grab his dog and hold on. The tremendous torque lifted the tractor in the air and slammed it on the ground.
    I saw my buddy at HQ back in his old truck, putting his gear in. Now, to be fair, the company was known to get the new trucks in, run them through their shop, and jack around with the engine parameters. For example, in my company truck (pre regen), they cut my power from 455HP to 350HP. The truck was anemic! The engine blew at 119k. They put me in another truck and gave it the same treatment.
    I get the feeling that if the company doesnt jack around with the factory settings on the ECM, it probably will be fine. I do know that if they cut them back too far, that affects EVERYTHING. Even the regen.
    Oxbow, stwik and Tb0n3 Thank this.
  6. kemosabi49
    10,977
    47,918
    Jan 13, 2013
    SW Arkansas
    I know a lot of companies anymore govern the speed down. But I have never understood cutting back the HP. Then the driver has to run it with his right foot on the floor all of the time. Leave the HP alone and let that engine breathe.
    Oxbow Thanks this.
  7. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Ask the hotdog who jakes to a stop at the fuel pumps, he'll know for sure.
  8. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    Not sure about that, but I definitely burn more DEF when I run the mountains vs running the flats. Few weeks back, filled up on Friday, truck sat all weekend. Monday and Tuesday ran Denver to Morrill, Ne. and back, I doubt if I burned 1/8 tank of DEF. Next three days ran Denver to Rifle, Co. and back. Come Friday, my DEF was almost on empty.
    As for running jakes for ext. periods of time, every motor is different, but about every 200K you might need an overhead run if you notice the jakes aren't running like they should.
  9. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,652
    Oct 5, 2012
    Earth
    I don't get why you would pull over to regen. Running the motor decently hard should provide all the heat the DPF needs. I've never once needed to do a parked regen.
  10. TripleSix
    133,411
    All kinds of things go wrong when the engine parameters are jacked up. I had a 9 speed top 2 transmission that was fine until they cut the power. It used to shift between 8th and 9th automatically, but when they cut the power, it would only buck back and forth in 8th. There was a way to bypass 8th, by turning the cruise off. It really hurt the performance losing 8th gear.
    Those big trailers coming out of the mountains spend a longer time on the jakes than any other. Factor in a junky ECM tune, and you may problems that only similar rigs will have.
  11. Dennixx
    Dennixx Road Train Member
    4,545
    14,617
    Feb 13, 2010
    twin cities
    You'll also need to ask at the shop for an extra gallon of jake fluid to keep in the side box for a really long grade.
    jammer910Z, Gumper and Mullet_Head87 Thank this.
