using mobil as base
Discussion in 'CB Radio Forum' started by Farm Trucker, May 4, 2012.
  1. Farm Trucker
    Farm Trucker Bobtail Member
    10
    i was thinking that since im having trouble finding a base could i hook a mobil cb like a cobra 29xlt classic up to a 12v converter (that i have) then hooked that to a base antenna would it work the same as a base?
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    if you use a mag mount antenna in the house, put it on a cookie sheet or a pizza pan.
    It's needed for the "ground plain" that would be missing from the vehicle.
  4. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Yes you can many radios can be run base or mobile ....
    Here is a example
  5. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    Yes it will work very well. Just use at least RG-8 coax.
  6. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    That is really all a base is; a mobile with a built in power supply. Which brings me to my point, be sure your power supply is big enough to run your radio.
    Channel Jumper, Big_m and WA4GCH Thank this.
