vaping in the mountains (ecig talk)
Discussion in 'Driver Health' started by msjs91011, Sep 23, 2014.
  1. msjs91011
    msjs91011 Light Load Member
    101
    12
    Aug 6, 2014
    I bet this wont get a lot of views, but here it goes anyways.
    I use (I think) a clearomizer... its basically the e-go battery with a tank that has a separate wick that can be replaced. Bought in missouri. Since then, ive been through almost all the US mountain ranges and every time I descend elevation, most of the fluid in the tank pushes out of the tank and all over the place. My question is: have you discovered a solution to the leaky ecig problem? Or am I the only one with this issue?
  3. Stormdriven
    Stormdriven Medium Load Member
    331
    217
    Mar 11, 2014
    south, central, US.
    I switched to 21mg patches and 4mg gum for extra stress-moments.
  4. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    If you Google Clearomizer Tank Leaking you will get a ton of hits.
    I don't know anything about Clearomizer or ECigs so don't really understand any of it. Might be some help/suggestions there.
  5. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    I quit smoking early this year after having a lung infection, I've been smoking since my teen years in the 60's. Later I started vamping, 1st I went with BLU, but that's quite expensive, them I bought one from our local LeCig store that just opened up in the small town about 6 miles down the highway. I've never had a leak but I don't travel though the mountains.
    There some forums on the net where you might get help with this. I did a search & came up with this, & some of them are speaking about trouble leaking. Mie is just the cheap Bottom Coil Clearomizer.
    I'm editing this to add a thought. Perhaps its to full, or maybe there trouble with the atomizer & its causing it to flood & leak out. Just guessing.
  6. dca
    dca Road Train Member
    6,834
    11,428
    May 31, 2011
    Earth
    That's why the pre filled filters are there.. bought one for a gift that held the users choice of a small amount herb to presoak in the users choice of oil thus helped with leakage the maker claimed it to be easier to clean as well.
  7. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,425
    Mar 23, 2012
    I'm using the faze vapor pen, it uses the 2 ml tanks as well.
    I just deal with it, I find that the single coil tanks overall work a lot better than their dual coil counterparts for a couple reasons.
    The biggest two being:
    1-The single coil tank fills from the bottom and as such, has only one seal to fail/leak from.
    2-While it is a single coil, I'm under the impression that it's considerably larger than a dual coil. Makes the hits a lot larger and a lot more pleasurable overall.
    Gone from about 17-22mg of nicotine a day from smoking reds to less than 5mg/day with this faze unit.
    Just gonna bite the bullet in a month or so and quit completely. Hard candies and toothpicks.
    Regret ever picking the god ###### cigarettes in the first place.
    dca Thanks this.
  8. dca
    6,834
    11,428
    May 31, 2011
    Earth
    Spoke with driver about an hour ago had a "storm".. the mouth piece makes it leak proof, the strength of the electric current adjusts the amount of intake.. said he had it 4 months.. quit buying smokes since..
