vcad for volvo
Discussion in 'Volvo Forum' started by Offroadjack, Nov 21, 2014.
  1. Offroadjack
    Offroadjack Light Load Member
    197
    52
    Jun 19, 2012
    im trying to find a cheap vcad system. so I can look up codes and reset my steering wheel center. so I can get the TCS light off and turn my speed up
    I found a few on ebay for around 1000 for laptop and vcad but I want to make sure it will work. who out there bought
    a system like that? and were did you get it from?
  3. bravoo67
    bravoo67 Light Load Member
    257
    35
    Mar 15, 2012
    Brooklyn NY
    got black VCADS box that you hook up to the computer and to the truck.. it was $600(?) i think and it was from China ..
    it came with some hacked software that I couldn install so then I bought VCADS separately
    and had guy installed it for me.. still the VCADS box didnt work
    so what I did was:
    - bought NEXIG USB LINK off the internet - it worked with VCADS soiftware that I bought
    on ebay for $150-200 (dont remember exactly) and had the seller to install it for me REMOTELY
    You are going to need laptop with windows XP - bought it on craigslist - used one for $100 over a year a go
    What I recommend is to buy a computer with whole bunch of diagnostic programs already installed on it -
    for the sum of 500-750$ you will get VCADS, Cummins, CAT and Detroit diagnostic programs ETC
    forgot to mention .. this computer with all necessary programs, you can find on ebay as well
    Good luck!
  4. Offroadjack
    197
    52
    Jun 19, 2012
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Well I have a more cost effective way for u if u have a steering angle sensor then u have a bendix abs ecu if you're volvo is newer then 06 u have it for sure. So go in Google search and u can download bendix software for free that will hook up to you're abs and calibrate you're steering angle sensor or any other sensor in the abs system it actually really user friendly
  6. Offroadjack
    197
    52
    Jun 19, 2012
    Will I need a nexis adapter?
  7. Offroadjack
    197
    52
    Jun 19, 2012
    Ya and mine is a 2009 im finding it hard to fine a vcad to work with mine
  8. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    U can use next or there is cheaper versions online being that u are not going use it everyday u can get something from online try searching for dpa5 if I remember correctly it's called Dearborn protocol should be ro u nd 400 I just got new nexiq yesterday and they run round 850 but I use it everyday so it's a little different
  9. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    If you anywhere around th e chicago area I could calibrate it for u, did u recently replace this sensor or replace steering shaft cuz unless u did either one of those chances are yo u re going to need a sensor as well they don't just go out of calibration on their own
  10. Offroadjack
    197
    52
    Jun 19, 2012
    Dang I was just in Chicago
    they replaced the steering box seals
