Ved 12 help
Discussion in 'Volvo Forum' started by Sdatruckinginc, Feb 23, 2019.
  1. Sdatruckinginc
    Sdatruckinginc Bobtail Member
    46
    20
    Jan 18, 2019
    need suggestions random power loss like derate but no codes has progressively worsened no air in fuel pressure good injector test good cylinder eq test good changed fuel pump just to see no change gonna start searching electrical connections do have abs and tcs light on
  3. Vekara
    Vekara Bobtail Member
    Sep 17, 2018
    Ground wire to check my advice, or alternator could make some crazy stuff on truck
    Sdatruckinginc Thanks this.
  4. Sdatruckinginc
    46
    20
    Jan 18, 2019
    Had alternator replaced it was throwing injector codes all good on it now
  5. Sdatruckinginc
    46
    20
    Jan 18, 2019
    Turned out abs and tcs light on causing random derate removed fuses and breaker runs perfect back to shop for brake work
  6. Sdatruckinginc
    46
    20
    Jan 18, 2019
    Turns out that wasn’t prob back to derate but not as bad as b4 now fuel tanks not equalizing this truck gonna make go insane both vent lines and vents clear no blockage but fuel going down in left and up in right my truck is possessed
