VED 12 Leaking Power Steering leaking
Discussion in 'Volvo Forum' started by Gabriel Chartrand, Oct 22, 2021.
  1. Gabriel Chartrand
    Gabriel Chartrand Bobtail Member
    10
    Nov 7, 2020
    2002 with leaking power steering from passenger side frame rail. It's coming from what it looks like a water/water exchanger. 2 Powersteering lines and there's 2 lines coming from the rear passenger engine block. What's this part? And can I bypass everything and add a air to after cooler at the front of the engine?
  3. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Yes you can just power steering cooler air cooler more effective.
  4. Gabriel Chartrand
    10
    Nov 7, 2020
    I managed to buy a plate exchanger on Amazon that will work just fine and relocate it to the front of the nose. The factory exchanger is made of metal and completely rotted out.
