Vibration from 35-40 mph
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hkench, Nov 14, 2022.
  1. Hkench
    Hkench Bobtail Member
    14
    Both when accelerating and decelerating.
    Bad U joint?
  3. Diversitycargo
    Diversitycargo Bobtail Member
    I had same problem last month. Check steer tires and replace drag link.
  4. Hkench
    14
    Brand new rubber all the way around.
  5. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    Where do you feel the vibration? In your feet? In the steering wheel? In your seat? All those can lead to different things.
    If you suspect a bad U-joint get under the truck and push, pull wiggle the driveline
  6. Diesel Dave
    9,645
    32,597
    Jan 20, 2010
    Hesperia, Ca.
    Slip-thru driveline shaft.
    armo Thanks this.
  7. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
