Vibration while driving down the road
Discussion in 'Ask An Owner Operator' started by Flatbedotr, Jun 24, 2025.
  1. Flatbedotr
    Flatbedotr Light Load Member
    103
    36
    Nov 26, 2018
    OK Guys--
    Anytime I ask a question you always help me out with an answer.
    While driving down the road and speeding up to around 50 and 60 MPH there is a vibration. Also the wheel will shake back and forth if not held firmly. I've looked at the steering connections and they all seem okay and not loose. Any guesses at the cause and solution to this issue?
    BTW--before this started to happen the truck was pulling a little to the right (a probable alignment issue).
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,957
    Oct 31, 2023
    Could be anything. Nobody can tell you what the problem is from behind a keyboard. You'll get a bunch of guesses. Take the truck to a good spring shop. There are endless threads here about this. Probably one posted every week.
    Vampire and D.Tibbitt Thank this.
  4. D.Tibbitt
    157,285
    Every truck Ive driven where the steering wheel shook like that it was kingpins needed replaced...
    Vampire and 77fib77 Thank this.
  5. Powder Joints
    7,996
    8,427
    Sep 25, 2007
    Rosamond, SoCal
    I had a steering output shaft break, the one exotong the steering gear box, shop kept saying nothing wromg, till one night whrn ot made itself evident as to where the vibration came from. Cost them the tractor and trailers when the tractor rolled over. 3 weeks of write ups for vibration from the front end between 45 and 60 mph
    D.Tibbitt and 77fib77 Thank this.
  6. Ridgeline
    22,746
    123,779
    Don’t guess, bring it to a good shop and have them go through it.
  7. KDHCryo
    KDHCryo Medium Load Member
    643
    995
    Sep 14, 2023
    Your truck? Company truck?
  8. Powder Joints
    7,996
    8,427
    Sep 25, 2007
    Rosamond, SoCal
    Company truck, brand new Cascadia. CHP listed the defextive output shaft as the cause of the accident, when it snapped I lost my steering at 60 mph. Not an idael situation, glad to be a live, got to meet my guardian angel, since he assist me getting out of the wreck, and no one was around for miles after I was out.
    Siinman and D.Tibbitt Thank this.
  9. Vampire
    Vampire Heavy Load Member
    774
    27,693
    May 14, 2011
    Transylvania
    I had mine replaced with an alignment as well. Drives amazingly better now.
    D.Tibbitt Thanks this.
  10. tinfoil_truckercap
    tinfoil_truckercap Bobtail Member
    7
    9
    Jun 30, 2025
    My two cents: classic front-end issue
    Most of the time a vibration at highway speed is related to your steer tires. The most common cause is the tires being out of balance. also check for any irregular wear patterns like cupping
    If balancing doesn't solve it, I'd check the suspension components like kingpins and tie rod ends for looseness or wear
    The fact that the truck was pulling to the right before it started suggests alignment issue, which could have caused the tires to wear unevenly and lead to the vibration. Anyway I would start by getting the steer tires balanced, as that is the most likely and least expensive fix
  11. sirjeff
    sirjeff Medium Load Member
    There could be a couple things at play. I went 12k into a vibration I had early on that ended up being worn out saddle plates from loose u bolts. Don't be me Check the free or cheap things first... U bolts, tires, alignment, steady bearing, u joints, make sure slip shaft isnt siezed.
    AModelCat Thanks this.
