Violation
Discussion in 'Questions From New Drivers' started by Trey1123:, Oct 13, 2023.
  1. Trey1123:
    Trey1123: Bobtail Member
    Hey guys am not sure what happened I went for a pick up today and it shows that I have 3 hours on my 14 HAR DOT I went on my second 30min break to use the rest room I got back roughly about 20min and change my log to on duty driving I got to a stop light and my log froze and my 14 HR DOT went from 1:46min to -22hr on my DOT am not sure what’s going on
  3. TripleSix
    133,525
    Take a picture of the HOS clock and a pic of the log for the day and post them here.
    silverspur and gentleroger Thank this.
  4. MACK E-6
    50,089
    238,984
    That’s weird. Did the clock somehow stop counting at some point like the way a video will hang up with a slow internet connection?
  5. Ridgeline
    22,742
    123,699
    did your company provide any training of what need to do if your ELD is screwed up?
    If not call them. get your log book out and fill in the past 7 days and today out.
    Go paper until they tell you it is fixed.
  6. Movingismylifeilovemoving
    Movingismylifeilovemoving Light Load Member
    230
    292
    Aug 5, 2015
    Also, any possibility of editing and fixing it with a split sleeper?
  7. Brandt
    Brandt Road Train Member
    4,632
    6,368
    Sep 17, 2012
    Try restarting the ELD or tablet
    Tb0n3 Thanks this.
  8. Lostmykey
    Lostmykey Medium Load Member
    387
    524
    Oct 6, 2019
    Had just started my night with a full clock and my Qualcomm went negative while driving… generated a violation, and then a few min later went back to normal. Best we could figure is the device was syncing and the servers didn’t have my break for some reason. Running a bunch of splits can also confuse the devices depending on which gets considered the short or long one, I’ve had to use edits to force it.
  9. bryan21384
    bryan21384 Road Train Member
    15,762
    34,354
    Sep 18, 2009
    Memphis, TN
    Mmmmm how long were you on on duty not driving?
  10. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    Considering he said he was going to the bathroom, I guess the question should be how long was he off duty but making dooty?
    If it was Samsara, it does that if you put the screen off. It will log you off automatically and when you turn the screen on and get back into system, it logs you in and updates your time. I've had a little bit of a shock with it too, but if you keep in mind about how long you've been on duty and such, then you can look at the times and see that it's not right and wait for it to update.
