VNL 780 2015 - I-Shift problem maybe transmission.
Discussion in 'Volvo Forum' started by Battlecruiser, Dec 29, 2018.
  1. Rickspacecommand
    Rickspacecommand Bobtail Member
    6
    7
    Dec 3, 2018
    I’ve been running my I shift with the clutch fan on for a few months during the hot summer months to prevent transmission overheating it works for me. Now that it’s winter I can drive usually with no issues having the fan connected
    back to the switch. You have a ribbon or clutch issue? If your truck runs without any issues when cool leaving the fan on will help. Volvo redesigned the coolant feature on the new I shift it’s a heat related problems that have caused many drivers problems.
    KB3MMX Thanks this.
  3. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    This doesn't sound like a problem to me..... Might have a clutch overheat abuse code though... Very common in these dumb things.
    The stupid iShift will start in 5th great normally if it "thinks" it can... Lightweight sensed like bobtail or very light loads.
    Does your suspension pressure readings seen normal lately? Like it's not reading lighter psi than you normally see?
    I couldn't stand my clutch taking the abuse from the stupid iShift... It would do it regularly in conditions it shouldn't.
    Side note, i think the iShift clutch problems we're more heavily based on software programming rather than hard parts... This is exactly why... It often Starts in gears higher than 1st !!
    ....So i had Volvo reprogram parameters to force the iShift to start only in 1st in "D" mode .... And up to 3rd in "m" mode
  4. Hottrucker 001
    Hottrucker 001 Bobtail Member
    10
    6
    Jun 16, 2018
    Well u could have a clutch problem input shaft
    Could be loose,ishift had issues with clutch
    Worn out around 400k.
    KB3MMX Thanks this.
  5. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    May be the transmission input shaft speed didn’t slow down enough to engage. Possibility are. Air leak on clutch system. Or part of clutch damper broken spring fall inside of the pressure plate component and block the pressure plate internal travel.
    KB3MMX Thanks this.
  6. Dzaro
    Dzaro Bobtail Member
    8
    Hi guys
    I have similar problem with my 2016 Volvo d13 ishift
    It’s at2612d with out +/- buttons
    Usually I’m pulling loads from 5000-15000lbs
    When I press D button always shift in 1st gear then 3rd,5,7,9,10,11,12 with 5000lbs
    When I’m bobtail starting from 5th and continues normal 8,10,11,12
    Actually when my red knob is pulled shifting is normal
    Truck is in neutral, I’m putting in drive mode shift in 5th and I’m releasing trailer brakes (red knob down) it’s going into 1st
    I try this
    Truck neutral red knob up
    Putting drive mode press little on acceleration pedal then press red knob down
    It’s not going into 1st
    I’m driving whole day normal pulling forward with 4th or 5th till I shut off my truck
    Can you please help me
    Thank you
  7. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    What is the "problem" ?
    That's normal standard behavior.
    I program my trucks to not allow starting in any gear higher than 1st in D and no higher than 3rd in M.
    Factory ishift programming is hard on the clutch life starting in higher gears.
  8. Battlecruiser
    Battlecruiser Bobtail Member
    19
    10
    Nov 30, 2017
    Sorry for the late reply, I had to change my transmission by volvo. I was lucky enough to have 2 months left on warranty. They said if I didn't have warranty I would be paying $20,000CAD.
    KB3MMX Thanks this.
  9. Dzaro
    8
    I don’t think is normal to pulling from 1st empty
    I drove manual transmission I never put in 1st
    I drove 5 different Volvo’s always shifts from 4,5 depends on weight
    For me that is for heavy loads uphill....
    Do you think it’s a programming
    It’s confusing for me the red knob when I press why shift down
  10. long hauler32
    long hauler32 Bobtail Member
    volvo ishift gos in revrse but no drive
  11. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    I don't know who taught you to drive a truck or car but starting in any gear higher than 1st is a convenience that you take the result of increased clutch wear as the penalty.
    If you set the transmission parameters to start no higher than first gear you will have MUCH LONGER clutch life... Same goes for any regular manual transmission vehicle.
