VNL no throttle and gauges inop
Discussion in 'Volvo Forum' started by KoehlerLandscape, Mar 27, 2018.
  1. KoehlerLandscape
    KoehlerLandscape Bobtail Member
    5
    I have a 2006 VNL and it sat for a year and a half after I had 3 operations and i couldn’t climb up in it to start it. I went out today and charge the batteries and started it but it has no throttle in the gauges are completely in operative. The center digital gauge doesn’t even light up and none of the sweep gauges work with the exception of the fuel gauge. I looked at fuse number 24, I think it was, a five amp fuse and it was good. Does anybody have any ideas? Thanks in advance.
  3. KoehlerLandscape
    5
    It was supposed to say “ has no throttle AND the gauges are inop”
  4. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    run two cables from battery psitive to firewall manifold main cab power and see most likely you cab is not getting enough power if this works need harness for the cab power
  5. KoehlerLandscape
    5
    Thx a lot. I will try this tomorrow. Is there a wiring diagram online or a pic that shows manifold main cab power?
  6. nasriza
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    you cant miss it if you look right behind clutch pedal on firewall you have the main plug and all the air connections right under this there will be two 13 mil bolts holding on 4 gauge cable take two cables from there and run directly to battery power both of them have to positives though no ground connection. try with jumper cables first should work usually.
  7. KoehlerLandscape
    5
    I found the terminals exactly where you described them. I jumped both terminals to positive and still no gauges.
