voltage high
Discussion in 'Volvo Forum' started by wallance, Jan 12, 2018.
  1. wallance
    wallance Light Load Member
    66
    7
    Jan 12, 2018
    I am running on the way and the voltage shows 15.2 around 2 hours.Then it shows around 14.6.I have checked the battary and even have the TEC checked my truck .They told me to replace the alternator.But I think the problem is just the regulator.
    Does Volvo 670 has the voltage regulator separate ?Can I just replace the regulator ?If so, where can I get that?
    Thanks!
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Regulatot is inside in alternator. Check wires on alternator. Ground and small wire for voltage sensing. If everything is tight replace the alternator. Dont run with high voltage or be ready for expensive electronic repairs.
  4. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Charge sense wire might be disconnected or bad connection
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
  6. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    I think op abandoned the thread
