Voltage Low in 2016 International Prostar below 12v
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Datboijean954, Jan 16, 2023.
  1. Datboijean954
    Datboijean954 Bobtail Member
    FL
    I have an 2016 international prostar Cummins engine i apparently was losing voltage below 12.v went to TA and told me i had dead batteries ok change all 4 of em, couple hrs later same thing happening losing voltage below 12.v…..i don’t understand he even checked the alternator it was fine what u think the problem is? Plz help
  3. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Batteries off the shelf take time to fully charge. You can’t just install them and start pulling off them.
    With the truck running, what voltage at the batteries (or inverter if it’s directly connected) are you seeing?
  4. 201
    201 Road Train Member
    12,814
    26,383
    Apr 16, 2014
    high plains colorado
    Bad ground to frame.
    ducnut Thanks this.
  5. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    Can be bad signal wire
  6. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    Sounds like your alternator is not charging and you got ripped off. A hard charging alternator will be hot.
  7. Goodysnap
    Goodysnap Road Train Member
    3,777
    9,209
    Jul 12, 2017
    Why would a brand new battery not be fully charged? It most certainly should be.
  8. 201
    12,814
    26,383
    Apr 16, 2014
    Actually, a hot alternator indicates a bad ground. I drove a Mack, started going through alternators, the boss asked, "is the alternator hot?" I said, can't even touch it. They ran another ground to the motor, and viola! I think the whole world has a bad ground today,,,
    bzinger and ducnut Thank this.
