Volts not showing on stryker SR 955
Discussion in 'CB Radio Forum' started by stacks, Mar 6, 2020.
  1. stacks
    stacks Road Train Member
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    I’ve noticed on my stryker the voltage does not show anyone using the same radio can explain how to go into the settings is it easy to set up
  3. Timin770
    Timin770 Road Train Member
    1,659
    1,768
    May 27, 2011
    Canton, GA
    Go to the function menu (hold down function button for about 2 seconds) and look for LCD: This option lets you choose if you’d like to display the following on the LCD meter.
    Rotate the channel selector to select the different options.
    The first option is to display the model name of the radio, the second option will show the DC voltage present at the power jack, and the third option will display the model name during receive and the voltage during transmit.
    (source: Stryker website)
    stacks Thanks this.
  4. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
  5. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    Thanks kindly bud
  6. Timin770
    1,659
    1,768
    May 27, 2011
    Canton, GA
    Your post made me want to dust off my 655 for a 3 day trip tomorrow. Plugged it in as a base station and discovered the channel selector is stuck on Channel 19. I'm still going to take it. I never use any other channels
    I told somebody the other day that if you super glued my channel selector on Channel 19 I wouldn't notice it for 6 months
    Meteorgray and stacks Thank this.
  7. Timin770
    1,659
    1,768
    May 27, 2011
    Canton, GA
    ***edit to above post. My power supply was not turned up to proper voltage, presumably causing my problem. After I got proper voltage all was well. Sorry to sully Stryker's good name lol
  8. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Free software fr stryker can let you in the radio to change radio name/freq/custom roger beeps if you have the cord thats needed..
    stacks and Timin770 Thank this.
  9. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    I have a cord there are a few videos on you tube About getting into the radio functions to show the voltage anyway radio is very quite heard a station
    Calling yesterday from TT on 27:3850 LSB he was gone as quickly as he shouted in .
  10. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    I’m more concerned about high SWR it’s low down on channel 1 rises a bit on 19 but on channel 38 it’s showing 2 on the built in SWR meter .
  11. Timin770
    1,659
    1,768
    May 27, 2011
    Canton, GA
    Certain stretches of road are nonstop chatter; others are dead as a doornail. I-26 between Greenville and Asheville seems to be busy every day. I'm sure there are other stretches just as busy
