volvo 2020 d13 coolant missing
Discussion in 'Volvo Forum' started by virgilantes, Nov 21, 2021.
  1. virgilantes
    virgilantes Bobtail Member
    6
    4
    May 14, 2021
    Hello , I have a Volvo 2020, D 13 engine, building a high pressure in the coolant tank, coolant is missing (@ 1 gallon need to be added every week). Any ideas what can be bad ? ( No coolant trace in the EGR cooler, no bobbling's in the fuel tanks, no fuel mixt with the coolant, no hard engine start) thank you for yours's attention.
  3. Lazer
    Lazer Road Train Member
    1,815
    2,898
    Jan 22, 2017
    What ‘high pressure’ numbers are you looking at? Is the radiator cap opening up? It’s possible the cap is weak, and opening before it should.
  4. calbertella
    calbertella Bobtail Member
    check cooloonat lines used to keep def from freezing ive heard of leaks in that portion of the system
  5. calbertella
    check the coolant lines that go to keep the def fluid from freezing ive heard with these mystery leaks or loss of coolant they been finding it there
  6. Siinman
    Siinman Road Train Member
    5,428
    13,928
    Mar 5, 2017
    Kansas City, MO.
    Mine just popped right there for a second time. But it is a 2014 Volvo 670. It will not just leak it will blow out in my instances.
