volvo 670
Discussion in 'CB Radio Forum' started by spanky37871, Apr 13, 2012.
  1. spanky37871
    spanky37871 Bobtail Member
    5
    new market tn
    how do you get the mirror apart on a volvo 670 to replace the coax and stud for a better antenna set up i have been told that the glass slides out then theres snaps to remove the cover but i had no luck with that
  3. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Can't help you with that except to say my brother drove a Volvo and they make a "bird perch" to replace one of the mirror mounting bolts for his model. Worked good!
  4. monkeypuncher
    monkeypuncher Medium Load Member
    459
    145
    Feb 28, 2009
    dallas,tx
    mike is right, it will also give you a better ground.
  5. spanky37871
    5
    new market tn
    ok thanks i realy wanted to put it back in the stock spot if i could cuz i dont like brackets and stuff hangin all over the place and cables and junk
  6. red_eye
    red_eye Medium Load Member
    440
    123
    Dec 30, 2009
    belpre, ohio
    there is 4 snaps on each side of glass.. flashlight and a long flat blade screwdriver.. the snaps break off easy..so watch it.. you have to look back inside and you will see the snaps
  7. monkeypuncher
    459
    145
    Feb 28, 2009
    dallas,tx
    it isn't a bracket, on the mirror mount you will see mounting bolts on the upper arm...take out one of these bolts and replace with bird perch about 5" long...now mount antennae..and your mirror is still in one piece, those plastic snaps are very brittle.
  8. cuzzin it
    cuzzin it Road Train Member
    3,643
    12,619
    Jan 19, 2008
    Berea, KY
    Very brittle and epoxy only holds for a while.......:biggrin_25510:
  9. spanky37871
    5
    new market tn
    ok thanks i figured it out had a buddy come help me i didnt know that the glass slides out so you can get to snaps better but got apart and only broke one lol but it went right back together and every thing works great thanks for all the help
  10. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    How exactly did you slide it out. I need to do it and cant figure how
