Volvo 770 01,Cummins Isx,low fuel pressure goin' downhill & idle (air in fuel lines)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Narcis.M, Jul 20, 2011.
  1. Narcis.M
    Narcis.M Light Load Member
    76
    13
    Oct 17, 2010
    Quebec
    Hello, I have a problem with my 2001 isx cummins /770 volvo, the check engine goes on with "low fuel dellivery " or something similar and truck run rough ,it happens usualy when goin' downhill and sometime at idle.I was twice at Cummings for this issue and the first time they replaced the secondary fuel pump twice and the second time the Davco fuel separator,a lot of money and time for nothing since I still have the same problem.In the tests they did you can see clearly air in the transparent fuel line that they installed .
    Thank you for your time and help.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    I start with fuel lines from tanks to filter, and I advice you to find diesel shop with CO2 in Fuel detector, becouse bad fuel injector may let exaust come in to fuel system.
    If no CO2 - do the fuel lines pressure test. ISX is not Volvo engine and you cant damage ECM/ECM cooling plate with damage, but you will see a leak
    Narcis.M Thanks this.
  4. Narcis.M
    76
    13
    Oct 17, 2010
    Quebec
    Thank you Pablo , will look into that .
  5. Narcis.M
    76
    13
    Oct 17, 2010
    Quebec
    I just changed yesterday all the fuel lines and fitings from the tanks to the fuel pump,everything is brand new now and I still have the same problem.It does this also with the tanks full with diesel so I don't think that is the fuel pickup line from inside the tanks.If somebody have an ideea please Lmk.TY
  6. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    As Pablo said, you may have a bad injector.
  7. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    [ame]http://www.youtube.com/watch?v=HTjNgKa_XnY[/ame]
    This is good video.
    bravoo67 and Pappa Bear Thank this.
  8. Narcis.M
    76
    13
    Oct 17, 2010
    Quebec
    Found the problem ,it was the fuel shut-off solenoid , the one that cut the diesel when the ignition key is turned off .
  9. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    change it with new. do not disable it else if engine saverevs nothing stops it till it is ruined
  10. Magnum1
    Magnum1 Medium Load Member
    567
    28
    Dec 13, 2010
    NJ
    Hello.
    my truck cranks lil longer b4 it starts and when it shuts down - it is kind of ruff shut down. any idea?
  11. Cummins600
    Cummins600 Bobtail Member
    26
    8
    May 18, 2011
    Pa
    Have the same problem with our 2000 Volvo ISX Cummins 600! The only thing is that we have already changed the fuel shutoff solenoid.
