Volvo d12 2007 fuel pressure problem
Discussion in 'Volvo Forum' started by salim patel, Jan 23, 2017.
  1. salim patel
    salim patel Bobtail Member
    40
    6
    Nov 15, 2015
    Hi guys d12 eng getting code for check
    fuel filter mechanic change ACC drive fuel pump fuel filter mount with the primary pump still same problem tryed supplying fuel directly through fuel filter housing still Same problem don't know what to do any help would be appreciated thanks. Sam
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    What kind of miles do u have, second thing have you ever done injector cups, and third is take a line from the return and see if there is bubbles coming out from the head good chance you are putting compression in fuel and your cups are messed up .
  4. salim patel
    40
    6
    Nov 15, 2015
    1.1 million miles no injectors or cups have been done going look in to it tks
  5. salim patel
    40
    6
    Nov 15, 2015
    Installing the cups now let you know asap tks
  6. salim patel
    40
    6
    Nov 15, 2015
    Gordon Light Foot Thanks this.
  7. salim patel
    40
    6
    Nov 15, 2015
    OK nasriza brother change cups check return fuel line still same low fuel pressure now mechanic is talking about defective fuel pump tomm he will bring onther fuel pump let's see what happens tks
  8. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Hold on did someone check the supply line from engine to tank make sure there is nothing stuck in the line what kind of fuel filters do u have.
  9. salim patel
    40
    6
    Nov 15, 2015
  10. salim patel
    40
    6
    Nov 15, 2015
    Yes he supplied air pressure from the right side fuel tank fuel comes to the water separator filter he allso supplied fuel from the bucket directly to fuel filter on the driver's side same result
  11. salim patel
    40
    6
    Nov 15, 2015
