volvo d12 egt, what's normal?
Discussion in 'Volvo Forum' started by dustinbrock, Jul 16, 2015.
  1. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    I have a 06 d12d 18 speed 4:30 gears.
    I haul 140,000lbs and my pyro is usually at 600, on a hard pull I will see at most 650 and if coasting on flat road 500. can be 35 Celsius out pulling a hill at 1200 or 1800 rpm and not above 650.
    if pulling hard and I go above 1850 rpm I will get a egr tempura ture value too high code which goes away when I drop the rpm again.
    turbo boost is 35 to 38 lbs, no leaks in system. I pressure test each service. oil pressure steady at 60, coolant temp cycles normal.
    just curious because I have read of guys hauling light loads with a d12 and way higher egts.
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    i would assume you're gearing and the 18 speed has a lot to do with it also the fact that you know how to drive and monitor everything with the truck is the reason you have normal egt some of these guys on here with high egt i believe are not familiar with d12 and some probably don't even pay attention
