Volvo d12 no power help
Discussion in 'Volvo Forum' started by Brcak108, Sep 23, 2017.
  1. Brcak108
    Brcak108 Bobtail Member
    32
    12
    Sep 13, 2017
    Louisville ky
    2007 volvo d12 auto trans did egr delete overhead oil rings air fuel filters and seems something is choking engine empty trailer takes 1 min to get it up to 65 mph hour on flAt road can anybody help please? No codes
  3. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    How did you do the egr delete...?
    Was it like this before the delete..?
  4. Brcak108
    32
    12
    Sep 13, 2017
    Louisville ky
    Volvo D12 EGR Performance kit | EGR Delete Kit | OTR Performance I did delete 3 months ago it was ok wasnt diff but no more check engine so 2 weeks ago no power last week run overhead change oil ring fuel air filters oil filters no difference took load to fl on my way back to ky empty nd im on 75 all flat land dont see no reason why i couldnt do 70 mph without problems look like its struggling nd chocking
  5. flood
    4,169
    4,051
    Dec 25, 2010
    If you had a BAD egr valve before you did that you still have a BAD egr valve now..
    The kit works by tricking the ecm into thinking the valve is working right so no egr code
    BUT if the valve was bad and is not closed 100% you will have a loss of power/bad fuel mpg/black smoke.
  6. Brcak108
    32
    12
    Sep 13, 2017
    Louisville ky
    So what can i do to close it 100% i check valves they was in closed position i hammer them down just to make sure and i only blocked two pipes for coolant didnr do nothing for exhust i tgought when i unploged egrs nd hooked computer that would kill power to egrs do they not functional
  7. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    check probably EPG Is getting Stuck Behind turbo.
  8. flood
    4,169
    4,051
    Dec 25, 2010
    Did you change the boost pressure sensor.. it will mess with you if it goes bad and doesn't thro a code when it goes bad
  9. Brcak108
    32
    12
    Sep 13, 2017
    Louisville ky
    I did when i installed this kit but how do u close egrs 100% what else i could block buddy of mine had working egrs when he installed this kit his truck pulls 30% better than it used to more power better fuel millage mine no difference
  10. flood
    4,169
    4,051
    Dec 25, 2010
    Some people pull them and weld them closed
  11. Brcak108
    32
    12
    Sep 13, 2017
    Louisville ky
    I might just do that cause my cross over pipes exhust part still get hot which means exhust still flow through them
