Hey guys I have a minor issue with my truck. It runs great, I have no fault codes, I have good power and good fuel mileage per gallon. On occasion when starting the engine it will just crank and crank and not fire. Usually when I try again it will fire right up like nothing ever happened and sometimes it takes a third attempt. I do always put the key into the on position for about 5 seconds before I turn it further to engage the starter. Someone recommended to replace the crank sensor, I had that replaced although still having this issue on occasion. Many times it will start with no issue but there are moments where it takes up to 3 attempts. Is this anything to worry about?
Volvo D12 occasionally won't start on first second and third attempt.
Discussion in 'Volvo Forum' started by Death Hauler, Oct 5, 2017.
Dreaded Volvo injector/injector cup fiasco........Search the topic. You will find much information.
Oldironfan Thanks this. -
Thank you for leading me in the right direction!
I dont know the answer, but I dont think it is the dreaded injector or injector cups, this issue was common on the D13 engine, but I dont remember it happening on the D12, it sounds like the truck this is a fuel priming issue.
Oldironfan and jsnell Thank this. -
I second this ^^^
fuel pump is a lil slow? early indication of fuel pump failure or air in the system.
You tried working the fuel primer plunger (driver side of the block)?Oldironfan Thanks this. -
I have a 2006 D12 and mine has done this since it was new. It isn't an injector or fuel pump issue necessarily.
Good luck,
JimBike rider and Death Hauler Thank this. -
Did you fix that problem?
Hmmm...problem fixed itself? Or u just burned out a batch of bad fuel?
New2D12 Thanks this. -
