Volvo D12 throwing code for injector 2 and jumping from 1,2,3
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EzcVNL, Nov 3, 2024.
  1. EzcVNL
    EzcVNL Bobtail Member
    28
    55
    Sep 28, 2024
    Just bought my truck a few months ago and figured I’d post things I’ve come across. I’m no mechanic but doing all the work myself. My wire harness was leaking from the injector harness when I bought it. I removed it and replaced the oring and placed it back with some rtv on the outside to buy sometime. So when my injector 2 started giving me a code I instantly thought it was the harness as I took it out and its brittle. I first unplugged the injectors and cleaned the plugs for the harness. Everything worked again for a week or two. Then it threw a code for injector 1 and then 3. So I was almost certain it would be the harness. Well I replaced the harness and while I had the valve cover off realized that the spring on injector 2 was broken. If you replace your own injector make sure you get the trim spec off the injector unless you have an aftermarket tune. After the injector and harness replacement I have had no issues with the injector since.
