Volvo d13 code
Discussion in 'Volvo Forum' started by Peewee 422938, Mar 21, 2019.
  1. Peewee 422938
    Peewee 422938 Bobtail Member
    5
    Mar 21, 2019
    i have a 2012 Volvo with d13 and I just got a code. Spn 3363 fmi 2. Can anyone point me to where I need to start looking?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Hi Pewee, not sure about your code, but you may want to invest in a code reader of some kind. Thy don't cost that much and can save your butt at times.
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Newto Trucking Thanks this.
  5. Rajatoor
    Rajatoor Bobtail Member
    15
    6
    Mar 19, 2019
    Hello, ECM SPN 3363, Aftertreatment Diesel Exhaust Fluid (DEF) Tank Heater
    90% that code come with battery terminals. Look your batteries clean all cable and terminals. Code will gone in day or two.
  6. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    I know def line that goes from the pump to the def dozer, the heater activates at below 40F outside temperature. So once you will begin starting the cold truck and driving it at 40F and up, you should be good till the next winter
  7. Oneel998
    Oneel998 Bobtail Member
    22
    6
    May 21, 2019
    Seen this code PLENTY of times. We are replacing the def level module. Had probably 3 trucks back to back in a week with the same code. Was worried it wasn't being diag properly and started talking with out tech support and they agreed the DEF level module is faulty. May not be your fault but without hooking up and looking difficult to say that's it.
  8. 41 cat
    41 cat Bobtail Member
    I'm curious about this suggestion. I have a truck that is new to me before this winter and have had "P20C113, def line 3 heater open circuit" code come up 2 times, both low def in tank, on guage and below freezing. It turns out that service records show line and harness have been replaced due to same code, just over a year ago... in January. Are you replacing the DEF level sending unit for the remedy to this? The timing of this code appearing seems like an occurrence with the low DEF and below freezing but doesn't seem logical to code definition. Thanks for any input!
