Volvo d13 cracked piston
Discussion in 'Volvo Forum' started by Lexu, Apr 8, 2019.
  1. Lexu
    Lexu Light Load Member
    63
    13
    Mar 26, 2016
    Hey guys. Need some help with my truck. 800 000 miles D13 engine 2013 I had the truck in the shop for a valve adjustment, replace engine harness and oil change. Took the truck out the shop and made 400 miles bobtail and 60 miles loaded when the engine went into protection mode. Stopped and the truck was blowing smoke and oil like crazy from the blow by hose next to the oil pan. Only from there. The back exhaust was normal. Towed the truck back in the shop and they took the engine apart. The mechanic found piston nr 6 cracked. What are possible causes for this to happen? Can it be just a coincidence that it happened after i had the truck in the shop? Before i took the truck in the shop the truck was not blowing smoke at all. The mechanic says probably bad injection timing. I had the engine tuned 40 000 miles ago. Thank you
    KB3MMX Thanks this.
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    coincidence
    QUALITYTRUCK Thanks this.
  4. truckdriver31
    6,998
    8,363
    Sep 18, 2013
  5. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    When you say you had it tuned 40000 miles ago. What you mean?? Egr dpf scr fix???
  6. Newto Trucking
    359
    226
    Dec 26, 2013
    NE Illinois
    Do you have a pyrometer gauge (exhaust temperature gauge)??
  7. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    How did the piston crack, dropped valve? If so, could be coincidence , misadjusted valves is the most comon cause.
    KB3MMX Thanks this.
  8. Lexu
    63
    13
    Mar 26, 2016
    Yes. Egr and dpf delete. And raise from 455 hp to 500 hp. Pdq performance.
  9. Lexu
    63
    13
    Mar 26, 2016
  10. Lexu
    63
    13
    Mar 26, 2016
    No. I do not have that.
  11. Diesel Power
    Diesel Power Bobtail Member
    45
    16
    Nov 1, 2016
    Bad tune. Common issue when you disable EGR Valve. Because of high fuel injection pressure and without egr its gets too hot in combustion chamber. EGR lowers temp in combustion chamber.
    KB3MMX and Newto Trucking Thank this.
