Volvo D13 - D11 I-Shift Interchange
Discussion in 'Volvo Forum' started by sully91, Aug 31, 2022.
  1. sully91
    sully91 Bobtail Member
    49
    13
    Oct 21, 2019
    Good day everyone!
    I have a 2016 D13 Volvo that needs a short transmission (bad spigot bearing and corrosion due to water from bad air drier). I have a 2016 D11 with I-shift that is a donor.
    D13 has overdrive and the D11 does not!
    Will the D11 I-shift fit the D13 I-shift? I am capable of programming the TECU since I would swap everything over.
    North American trucks. Just wanted to throw that out there.
    Thank you!
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    can not swap them,
  4. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Mechanically speeds will be to far off from the truck being able to shift properly need to replace overdrive with overdrive or direct with direct.
