Volvo D13 Engine Fault, Code is: SA 16 DTC P24AF00
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Xpendable, May 23, 2025.
  1. Xpendable
    Xpendable Bobtail Member
    May 4, 2025
    Thanks Received:
    This points to the PM/NOx sensor... would it only be the outlet sensor only, or can it also be for the inlet? Would cleaning it help in this scenario, or is it best to replace?
    Is the sensor just replace and go, without the threads fighting? Engine has not derated yet, but don't plan on using it until attempting to fix it. Does anti-seize do enough to help protect the threads or is there something better?
    Thanks.
  2. Mdavid0614
    Mdavid0614 Bobtail Member
    Feb 13, 2019
    31
    Thanks Received:
    6
    Its the PM sensor or particulate matter sensor not nox. It wont throw you into derate never so you dont have to replace it right away besides check egine light
