VOLVO D13 - I-shift transmission air leak
Discussion in 'Volvo Forum' started by JerryD13, Oct 3, 2018.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    2012 - VOLVO D13 - iShift Error >"Transmission LOW Air Supply" - Image Attached.
    *getting error message on the dash "Transmission LOW Air Supply"
    also getting the error on dash > "check the transmission at the next stop"
    Please advise on this iShift Transmission issue.
    620K on Transmission
    Thanks much
    ishift, volvo, vnl transmission
  3. sirjeff
    sirjeff Medium Load Member
    Just a hunch but there is a crappy air fitting either up on top or on the left side near the top that is prone to failure.I wish I could be more specific but that's all I can tell ya. Hopefully it's something simple like that!
    BUMBACLADWAR, NoBigHurry and JerryD13 Thank this.
  4. Benek
    Benek Light Load Member
    83
    39
    Feb 10, 2016
    There are 2 air fittings,they leak often,usually I replace them once a year or so. One of them is leaking right now, but you must be leaking big if you getting a message on board. Crawl under with soap water and go nuts. If it's them u should find out quickly
  5. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    Check air firing on drivers side of transmission. They had a recall with redesigned fitting for this problem.
    You'll hear it leaking with the truck off...
  6. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    there is an air tank on pass side of truck connecting to the three regular air tanks, this tank is the transmission air tank on the inlet you will find a pressure control valve, replace this and then try to see what happens probably valve is stuck and not letting the right amount of air in, if it is not valve then in will be a pressure sensor in the trans most likely.
    Muratti, Stringb8n, yoandy and 9 others Thank this.
  7. JerryD13
    169
    126
    Oct 17, 2016
    Thanks again NazRiza - you got this one correct again - after replacing this 35.00 part
    * Pressure Control Valve * $35.00 @ Volvo dealer
    the error "Transmission LOW Air Supply" disappeared!
  8. JerryD13
    169
    126
    Oct 17, 2016
    issue resolved
    KB3MMX Thanks this.
  9. KB3MMX
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    You rock nasriza !
    20 Mule Team Thanks this.
  10. 86scotty
    86scotty Road Train Member
    4,819
    13,274
    Aug 27, 2017
    Appalachia
    No doubt! I love this board.
    Hey Jerry or Nasriza, how hard is this to swap out?
