Volvo D13 need advise
Discussion in 'Trucks [ Eighteen Wheelers ]' started by maxya1986, Mar 6, 2015.
  1. maxya1986
    maxya1986 Light Load Member
    73
    13
    Feb 17, 2015
    I've got 2012 Volvo with D13 engine and Ishift, my fuel economy really bad. Truck ,makes less than 5 mpg, even while it's idling it takes more than a 1 gph. I did't find any air cooler leaks. I replaced turbo boost sensor, old one was really dirty and no changes. So now I thing my poor fuel mileage because of EGR problem. There is a code on my dashboard SA 0 SPN 411 FMI 8 I can't find what that means. Any thought? Or can someone help me to find what that code means?
  3. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Differential pressure sensor mechanical or electrical fault
  4. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I have 1,433,000 miles on original Volvo D13/2008 still getting 7.5-8 mpg with all this cold weather in Ontario pulling dry van , 62mph,average weight loads;
    are you pulling heavy? cold weather? mountains, driving fast? I had problems with both EGR and diff pressure sensor, could be the problem; I would replace the differential pressure sensor first; you can do it yourself; about 120$;
  5. maxya1986
    73
    13
    Feb 17, 2015
    Just replaced Differential pressure sensor today as you advised. Did you have bad fuel mileage because of that sensor?
  6. Johny41
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    no, but when goes bad/codes , usually clogged with egr shots derates the motor 20-30% , maybe on your 2012 model with DEF works on different software; I'm happy with this motor, not perfect but every year my real average was around 8 mpg;
