Volvo D13 Starting issue
Discussion in 'Volvo Forum' started by Matharu_R, Jun 30, 2023.
  1. Matharu_R
    Matharu_R Bobtail Member
    8
    Aug 29, 2021
    I Have volvo D13 2015 with 1050000 kilometres. It’s having random long crank hard start problems. No problem starting early in the morning even in winter but when the engine gets warm its gives this problem once in a while, keeps on cranking but doesn’t want to fire up. I’ve had the injector cups and fuel filter housing replaced recently regarding this problem but still same issue. If someone can help please reply
  3. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    I think you may be better off by asking the moderators to move this question to the diesel mechanics sub forum. You will probably get more help there.
    There are several easy diagnostic steps you can take without spending a lot of money. First would be to get a fuel pressure gauge on the low pressure fuel system and verify that you have a reliable, consistent fuel pressure.
    Next, with a scan tool you can see what the engine ECM is reading from the high pressure fuel system. You will be able to see the commanded fuel pressure and the actual. These would be my first steps.
    88 Alpha Thanks this.
  4. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    I moved it to Volvo in our Garage section.
  5. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,358
    Nov 1, 2017
    The Sticks, Idaho
    Does it have a Davco style filter? If so check that its not letting air back into the system... Ive had 2 or 3 trucks do almost that exact same thing because davco was leaking air back into the system and it would lose prime.
    kwt600, KB3MMX, Siinman and 2 others Thank this.
  6. Matharu_R
    8
    Aug 29, 2021
    Yes i found bubble in that thnx man
    KB3MMX Thanks this.
  7. Matharu_R
    8
    Aug 29, 2021
    Thanks man i found some bubbles in the davco filter i don’t understand how mechanics missed it
    KB3MMX and Siinman Thank this.
  8. ridlebalsinde
    ridlebalsinde Bobtail Member
    Jul 18, 2022
    so did you replace the davco filter?
    KB3MMX Thanks this.
