VOLVO DEF ISSUE
Discussion in 'Volvo Forum' started by sammaxlee, Nov 16, 2021.
  1. sammaxlee
    sammaxlee Bobtail Member
    33
    Jun 20, 2019
    My truck is 2014 D13 ENG,I got sign "poor DEF quality detected "
    Could you explain about this and how I can fix this issue, thanks a lot
  3. Ross_Tech
    Ross_Tech Light Load Member
    133
    134
    Aug 31, 2021
    It could be a few things, but if I had to bet, it would be that you have a large chunk of crystalized def in the decomp tube and a cracked doser mounting flange. Theres a flex pipe between your DPF and SCR that has the tendency to allow DEF to dry up and restrict the ability of it to make it to the SCR. The computer has no way of knowing this, so it assumes that you have poor DEF quality. If you take that flex pipe out and clean it, it will fix the problem temporarily. There's usually a crack in the def doser mounting flange where it is welded to the bottom pan of the DPF also. There may also be upstream issues causing excessive DEF dosing, which can make the issue worse. Prime suspects are plugged EGR cooler and delta P ports.
    86scotty, QUALITYTRUCK and loudtom Thank this.
  4. Siinman
    Siinman Road Train Member
    5,522
    14,206
    Mar 5, 2017
    Kansas City, MO.
    Might be NOx sensor issue.
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    there is a lot of things it could be usually there has to be some codes associated with this if not its a very very very expensive guessing game about what the problem really is you can start with nox sensor all the way to different engine components.
    Ross_Tech and QUALITYTRUCK Thank this.
