Volvo DID
Discussion in 'Volvo Forum' started by Rollin heavy, May 18, 2017.
  1. Rollin heavy
    Rollin heavy Bobtail Member
    My DID flashed AL then CH I think the AL is (air low) can anyone tell me the CH. It won't go into gear untill the CH stops and the N appears.
  3. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    174
    Oct 29, 2014
    Carlingford NB Canada
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    ^^^^^^ Been wondering the samething.
  5. Burdisco
    Burdisco Light Load Member
    119
    53
    Apr 25, 2015
    You have the zf freedomline transmission. Google The Gear Centre in Mississauaga Ontario. They have associate stores across Canada are the Zf dealer for Canada. Al is air low, Ch is system check gearbox. So it's running a check of the system. Once the truck is running and air built up al goes out and it goes into N. Ch should not be on if truck is running, if it is , you have an issue. if you search ,on line, you will be able to find the shop manual with all the codes and what to do when you get a code.
  6. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    even more ?????????????
