Volvo Fault Question
Discussion in 'Volvo Forum' started by cbt09, Feb 1, 2014.
  1. cbt09
    cbt09 Bobtail Member
    I have a 2007 Volvo VN series truck with the D12 engine and Meritor 12 speed Auto Trans. The truck has 618,000 miles on it. In the Diagnostics menu, I pulled the fault codes from the Vehicle ECU and received the following with an occurrence rate of 255 times: (MID144 SID231 FMI2) with the heading "J1939 Data Link Fault".
    From the Transmission ECU I received a J1939 Data Link Fault with 4 occurrences.
    From the Brake ECU, I received a J1939 Data Link Fault with 5 occurrences as well as a Power Supply fault (MID136 SID251 FMI3) with 25 occurrences.
    The truck keeps giving the "SM" on the dash readout and the truck will stay in one gear without shifting up or down, and this usually causes the engine to stall. The ZF Meritor technician that I spoke with on the phone said that the transmission is going into Manual Shift mode, and he said it could be anything from a sticking Brake Switch to and ABS module problem to anything at all. He said you have to have the computer with the relevant software to really get to the heart of the problem. The active code that my driver retrieved while the "SM" was displayed was "E7". Inactive codes were "37, 91,92". I know that 37 refers to the clutch actuator, not sure about 91 and 92.
    Last week, I replaced both Camshaft/Crankshaft sensors because the Diagnostics menu showed multiple faults and the engine turned over too much before starting, so that problem is fixed.
    Any info would be appreciated.
    Thanks
  3. DrivingForceBehindYou
    DrivingForceBehindYou Medium Load Member
    546
    184
    Aug 29, 2012
    ChicagolandOfOpportunity
    Sounds like you need a hacker not a mechanic.
    I'd try CTI from Normal IL to diagnose the issues.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    fix ABS problems firrst!
  5. juvic091779
    juvic091779 Bobtail Member
    pharr,tx
    hello guy,
    i have a problem my 2007 volvo just gave me an abs code it reads as followed mid 136 sid 78 fmi 2. can you all help me with it please?
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what Volvo VN ore FH? do u know ABS unit location?
  7. juvic091779
    pharr,tx
    Thanks for the reply Pablo. Its a vnl780 the location of the abs unit is under the cab
  8. juvic091779
    pharr,tx
    i was just under the truck and it has the bendix esp box under the cab in right side of the frame.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ouh, so look for usual corrodion problems
