Volvo FH13 EEV - Low air warning problem
Discussion in 'Volvo Forum' started by IordanDelchev, Jun 27, 2020.
  1. IordanDelchev
    IordanDelchev Bobtail Member
    Hello all. I have a problem with Volvo FH 13 2011 EEV . Sometime the needle for air pressure on the cluster drop to zero and warning buzzer for low air pressure it's on. After some seconds or minutes all things come back to normal and the needle is back on normal position. It's may have a problem in the cluster, like bad solder, bad stepper motor or something else? Anybody have some idea ? Thank you in advance for helping !
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Most likely bad air pressure sensor or sensor circuit.
  4. Doni04
    Doni04 Bobtail Member
    Were you able to find the problem?
    I am having same issue!
