Hi! I have a problem with 2000 year Volvo FL6 250. Cruise control works rarely. Sometime once
at first try, sometime works all day, sometimes it doesn't work for weeks.
The resume switch is checked and cleaned, its plug is checked.
Eny ideas?
Volvo FL6 250 PTO Cruise control problem
Discussion in 'Volvo Forum' started by JoelFL6, Apr 11, 2019.
What engine? That would help narrow the possibilities.
My 2015 VNL was doing the same thing couple years ago. Turned out that the wiring harness was not installed properly at the factory and after rubbing for year got short. Had to put the new harness.
Engine D6A250
184kw/250hp
5480cc -
I drove a vn 630 done same thing but would work most of the time when pto was engaged had to turn key off and let it reset and it would start working for a little while and then do the same thing somebody let us know ow what it is please
Sometimes doing this:
Yes and it works again or just holod the resume and it will work the. PTO solenoid went out to and had to buy pass it. I wounder if volVo has a fix other than a new wire harness and 3weeks down time.Or do they care they have a problem.Thats why my company is now buying Kenworth's
Problem solved! Brake pad and clutch pad switch was broken.
