Volvo gear selector
Discussion in 'Ask An Owner Operator' started by volvo1F, Aug 21, 2023.
  1. volvo1F
    volvo1F Bobtail Member
    Dec 24, 2022
    I have a 2016 Volvo vnl 780 this one has a base gear selector no + and - to downshift and neither the power or performance bottom.
    Have somebody here swap gear selector for the one how has those bottoms ?
  3. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    From what I've read, if your truck isn't programmed for manual mode, it still won't let you shift gears with the +/- buttons. I don't know if it's a setting in PTT or something in the ECM to reprogram, though.
    Siinman Thanks this.
  4. Siinman
    Siinman Road Train Member
    5,515
    14,177
    Mar 5, 2017
    Kansas City, MO.
    That is correct, Just adding the shifter in will not do anything. You will need to add the program in the ECM for the correct settings.
    These are the settings I have for my shift logic.
    Comprehensive w/ Gentle Shift Transmission software – US20Transmission software – Inclusive drive mode selection with less aggressive gear changing
    RSWDL Kit # 85156555
    RSWDL Name - RSWDL - Trans Pkg Comprehensive w/ Gentle Shift
    A software package targeting livestock haul, bulk liquids in smooth-bore tanks, recreational vehicle applications and similar applications where load shifting must be minimized.
    For customers that want all of the comfort and performance features available with the premium shifter in addition to fuel efficiency features. This software package also revises the AMT’s shift strategy to provide smoother launches, less aggressive shifting and more gentle driving.
    (slower torque ramps before and after a gear shift and torque reduction in low gear)
    It allows the driver to select the starting gear, shift manually and switch between the following drive modes.
    •Extra Economy (EE) •Economy (E) •Performance (P)
    This software package also configures / includes the following features :
    Transmission Kick-Down – Enabled
    Manual Adjustment (gears) In Automatic Mode - Enabled
    – Driver can adjust starting gear (which gear to start in using +/- buttons , on shifter)
    – Driver can adjust what gear to use when driving with the pedal using +/- buttons , on shifter Soft Cruise – Enabled
    Transmission Performance Mode – (Auto)
    – (The transmission will automatically return to Economy mode when the engine is no longer operating under high load)
    AModelCat and loudtom Thank this.
