Volvo/Hendrickson Front Axle Pressure
Discussion in 'Volvo Forum' started by bossboy2, Jan 6, 2017.
  1. bossboy2
    bossboy2 Light Load Member
    264
    60
    Aug 20, 2011
    Houston, TX
    Got an '07 Volvo VN with the hendrickson front axle. I'm confused with the weight readings I'm seeing on the D.I.D. and was wondering what other drivers are showing for their readings. My front axle reading is showing 110 and the rear axle is showing about 55-60. The last Volvo I had showed around 35 in the front axle. These are all loaded weight readings.
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I think your last one was out, mine shows 100-110 loaded.
    KB3MMX Thanks this.
  4. Trkr3529
    Trkr3529 Light Load Member
    104
    66
    Feb 14, 2016
    Same here 95-105
    KB3MMX Thanks this.
  5. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    What's the loaded pressure differences between the 12.5k & 13.2k air ride front axles?
    Does the 13.2k air use bigger bags?
  6. d281833
    881
    919
    May 15, 2012
    Probably just a little beefier axle.
