Volvo Isx won't start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nhra3195, Feb 26, 2016.
  1. Nhra3195
    Nhra3195 Bobtail Member
    I have a 2006 Volvo with Isx Cummins. It is throwing codes mid 128 pid 95 fmi 0. Also throwing mid 128 pid 94 fmi 4. Truck will not start, changed cummins fuel filter on engine block, no change in performance.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Check fuel shutoff solenoid, wire came off my N14 and truck shut down driving down the road.
  4. Nhra3195
    Thanks for the response, shut off solenoid was replaced a week ago
  5. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Will it run on ether?
  6. joe016
    joe016 Light Load Member
    120
    29
    Jan 23, 2016
    Anything happen before it did not start did you replace anything or just park it and then it won't start ?
  7. AModelCat
    165,475
    Does Volvo use an electric lift pump on their ISX's like Paccar does? Maybe the lift pump is shot?
  8. Cory wood
    Cory wood Medium Load Member
    335
    162
    Nov 7, 2015
    Yes they do, all the isx motors have an electric pump and a gear pump. Any chance you can hook up a fuel pressure gauge while cranking? Should have over 50 to start and around 250 while running when everything's in good shape. Had this happen to an isx just last week and it was only making 40 lbs cranking and would not start. New lift pump and gear pump and all is well.
    AModelCat Thanks this.
  9. shurenough
    shurenough Light Load Member
    66
    36
    Feb 24, 2016
    Sensor in the radiator may be messed up. I had to top off my antifreeze on the radiator to get that sensor to allow my truck to start. I had a international 9400i that had an isx Cummins. It looked like it was full but it wasn't enough antifreeze
