Volvo isx15 A/C issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by pete159, Jul 11, 2021.
  1. pete159
    pete159 Light Load Member
    108
    70
    Dec 6, 2008
    mississauga
    My cab AC does not blow very hard for long I have to turn off AC ond recirculation and crank the fans for a few minutes then turn the AC back on. Also there's lots of water dripping out the bottom of the truck and more than normal. I changed both the cab and bunk air filters. The water leaking is coming from somewhere behind where I am pointing not those two pipes
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    More than likely your heater core is leaking. You have to have the housing removed to see where it is leaking from.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Behind those two pipes is a rubber drain plug, make sure that it is not clogged up.
  5. Nss
    Nss Light Load Member
    128
    257
    Jul 5, 2021
    System is low on refridgerant, works for a bit, freezes up, then when you shut off a/c thaws out a bit and drains hvac box.
  6. Nss
    128
    257
    Jul 5, 2021
    No air flow across evaporator so no cool air out cab vents
