Volvo Problems
Discussion in 'Volvo Forum' started by Mr Bob, May 21, 2020.
  1. Mr Bob
    Mr Bob Light Load Member
    272
    84
    Mar 17, 2015
    For anyone who may have gotten a Volvo recently. I have come across some inherent problems that you might be interested in. These are VNM Volvos. Engine fan ( electric ) wire harness from fan may chaf through very easily, I use 1/4 inch fuel line to help them live, if the wire shows through slobber some high tack in there. The fan bracket may also be loose. Wiper motor housing screws may be loose or missing. Rear hub seals may leak prematurely. Fan shroud bracket bolts may be missing. Rear shocks may be loose. Check all wiring and hoses that may be chaffing through on the frame rails.
    Snailexpress and baha Thank this.
  3. SergeyN
    SergeyN Bobtail Member
    17
    Apr 18, 2020
    + even if this is a new truck, inspect the headlamp wiring harness and oil leak at the rear of the engine, and you also need to grease the handles to open the side fairings
