Volvo tnl 2017 wont start code J1939
Discussion in 'Volvo Forum' started by Roman78, Jul 24, 2021.
  1. Roman78
    Roman78 Light Load Member
    74
    27
    May 20, 2021
    Cuminication error with ecu Truck shut off while im driving on the highway. Sitting on shoulder as we speak
    Beck97 Thanks this.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    On the driver's side, just above the batteries, there should be a battery disconnect switch... turn it off.
    Then on the driver's side of the engine, flip the levers on the ECM plugs to push them out, one at a time, then relatch the levers. If there's a flaky connection at the ECM, that should take care of it.
    Turn the battery switch back on. If the truck still doesn't start, repeat one more time.
    Roman78 Thanks this.
  4. Roman78
    74
    27
    May 20, 2021
    Thank you bro. Will try that.
  5. dbny5000
    dbny5000 Light Load Member
    95
    56
    Dec 24, 2011
    San Francisco, CA
    what's your report on what happened? Bad ECM?
  6. YuriyKhodas
    YuriyKhodas Bobtail Member
    Same thing was with my 2012 Volvo ended up blown fuse FE4 30AMP it’s under hood next to a steering column
